SMEG DW 164 Door thermostat
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG DW 164 Door thermostat
  • #15488
    PeterRC
    Quick question for the enlightened out there… Is the door stat a temperature sensor or a go /no go device? I’m trying to debug E3 fault code and am working my way through the power cct. Element and main stat are OK, so door stat and Relay are next suspects.
    #163786
    Dave_Conway
    Re: SMEG DW 164 Door thermostat
    It’s a sensor (thermistor) 🙂
    #163787
    PeterRC
    thanks, it’s showing a resistance swing across the freezer to boiling water range so it’s probably OK I guess. Control pcb relay is looking like the culprit – off to find my soldering iron !
