Smeg DW DWF614SS
  • #41202
    Lawrence
    Wierd one this ,fault is the machine gets to 2 mins on the display then reverts to 5 mins and washes for ever.
    Tried PCB ,NTC ,it drains okay.
    When it gets to 2 mins the water is still hot .
    Lawrence
    #269122
    Re: Smeg DW DWF614SS
    Not sure if its right for this model but had a heater cutting out before the water gets hot enough. It would run long enough to trick the NTC and PCB into thinking all was ok, hence no error code. Especially so if it is the one with the torpedo inside the heater. If you have changed all you have said then cannot think of anything else really.
    #269123
    Thought the torpedo was to be disposed of?
