Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Smeg dw1 710 e1 Dishwasher
- This topic has 6 replies, 3 voices, and was last updated 21 years, 11 months ago by
wizard.
April 22, 2004 at 5:32 pm #5410
wizard
ParticipantCan anybody help ? I’ve been to one of these today & fitted a new start cap on the circ motor. After doing what I thought was a reset I’ve ended up with the two leds on the left on together & the far right one flashing. The machine now runs constantly. Have I accidently put it in some kind if test prog ? If so how the heck do I reset it – I’ve already tried holding the prog button down, but all that does is bleeps once & goes back to two on & one flashing again. Help !
April 22, 2004 at 7:48 pm #110962kwatt
KeymasterWizard,
Just so you know that we are paying attention, I don’t have the codes to hand but I do have them in work (as will others I suspect) so if no-one answers this before then I’ll tell you in the AM.
There was a thread on the public forums that I think Shane answered that gave the reset procedure for most of them. IIRC, it’s power off the appliance from mains and press and hold the program button within 3 seconds of reapplying power until it bleeps.
April 22, 2004 at 8:42 pm #110963wizard
ParticipantRe: Smeg dw1 710 e1 Dishwasher
Thanks Ken, I remember seeing that one too & I tried that, but it still comes back on with the two leds on & one flashing. – Almost seems like I’ve initiated some sort of self distruct sequence ! Where’s 007 when you need him ? I’d appretiate some info if you can have a look tomorrow AM though, Thanks again.
WizardApril 23, 2004 at 8:46 am #110964Dave_Conway
Wizard,
According to Smeg’s fault code list, two lights on the left on all the time and the one on the right flashing means no heat.
I would imagine that when the motor cap failed no water circulation has caused an overheat thermostat to trip.
HTH
April 23, 2004 at 10:10 am #110965wizard
Thanks for looking that up Dave, much appretiated. I’ll try that, but it only started doing it after I tried to cancel the program initially, machine had only been running for 2 mins. I’ll let you know later what occurs. Ta
Wizard
April 23, 2004 at 5:21 pm #110966wizard
Sorted !! safety stat was OC. Shorted that out & still wouldn’t cancel, so removed the outer door & shorted the cycling stat aswell. Machine made a load of beeps, pumped out & reset !!! So all I’ve got to do now is order a new safety stat. Phew!! What a git ! Thanks for your help lads.
WizardApril 23, 2004 at 6:16 pm #110967Dave_Conway
Not a git, a magician 😀
Now can you make my credit card bill disappear please 😆
Glad you got it sorted.
