Smeg DW1612c Dishwasher Leaking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DW1612c Dishwasher Leaking
  • #22949
    Twoten
    The above integrated dishwasher starts to leak at the lower edge of the door after about 25 minutes once the water gets hot.
    I have removed the door panels and noticed there are signs of leaking along the edge of the bottom door seal. I have removed the door seal checked for damage, cleaned and replaced but the problem persists.
    The water level looks OK. The only option I can see is replace the seal but as I can’t see a problem with the old one I’m not convinced this will resolve the problem.
    Is this a know problem with these machines?
    Any ideas would be appreciated.
    #196621
    Re: Smeg DW1612c Dishwasher Leaking
    Not a common problem at all, dont want to suggest the obvious but have you checked for clean and free turning spray arms?
    #196622
    Twoten
    eastlmark wrote:dont want to suggest the obvious but…
    It’s the obvious that gets missed so any suggestion is welcome.
    I did have a quick look at the spary arms but thought it would have leaked before it got hot.
