First customer calls, LED 3 on, not flashing, nothing happening.
I do reset proceedure and get LED 1 flashing, shut door and pump works and doesn’t stop.
I do reset again and LED 4+5 flashing, shut door and just pump again. No leaks in the tray so any ideas welcome. Not a fault listed for this.
Thanks.
Rob
With spurious fault indications like this you can only check the obvious like earth faults, wiring harness etc….if it’s none of those then the pcb is a gonner 😕
Lawrence this is true 😀 , however this normally causes the machine to give a spurt of life then stops, and continues like this until switched off 😕 . I have not found this coil to give a display fault though. However I have been wrong in the past and no doubt I’ll be wrong again 😳 .
Oldtog wrote: I have not found this coil to give a display fault though. However I have been wrong in the past and no doubt I’ll be wrong again 😳 .
Oldtog
