Smeg DW171061
  • #29212
    M1
    Type 12043 Nr 151940802 Approx 2 years old
    Just been out to this Smeg DW and it fills the side presure chamber,then just pumps the water away.
    There is no fault code window just the far 3 left lights flash, (rinse delicate & normal wash lights).
    The presure chamber is clean both valves are OK.
    Any ideas ???
    Cheers
    #222320
    DentedPorsche
    Re: Smeg DW171061
    Look in Known Error Codes. Page 4 if I remember correctly.
    If it’s the flowmeter problem just do a search for smeg and reset, I’m sure it’s documented here somewhere.
    Brian
    #222321
    M1
    Re: Smeg DW171061
    Just done the reset procedure & all works fine.
    Cheers !!!
