Re: smeg DW1710E Dishwasher wont start
Update: reminded myself of some of the more common problems associated with dishwashers from somewhere else on the site. So far I’ve tested the motor, heater element, and anything else I could find (the machine is disconnected from main), also checked continuity on every part of the harness checking for breaks below the door, all switches ok. I’ve got the pcb out had had a good look – can’t see any dry joints or obvious signs of overheating.
Has anyone come across a fault like this? Its looking more like the pcb which is around £145 – its odd that the program indicator lights are still on but not flashing.
Any advice as to where to go next would be appreciated.
