Smeg DW45.1 Dishwasher problem..
Home Forums Public Support Forums General Enquiries And Questions Smeg DW45.1 Dishwasher problem..
  • #66809
    ole
    Hi all,i’m new on here,hope you’re all well 🙂 I have a problem with my smeg integrated dishwasher DW45.1,whenever i switch it on,on any setting bar the quick rinse one,the cycle won’t finish,it washes ok,but after a couple of hours,i have to switch it off and reset it to quick rinse to drain it..being a novice,i can only think its a control board fault,any ideas anyone?
    Thanking you in advance…
    #365277
    Re: Smeg DW45.1 Dishwasher problem..
    What lights are on or flashing when it stops? It’s probably halted on an error which is good as it is therefore likely not the control PCB but something else that is faulty.
    ole
    hiya,thanks for your reply,the problem is,it doesn’t stop! it would carry on all day if i don’t switch the power off.I then switch it back on,and press the button 4 times so it resets itself,but the water still needs draining out,which is why i put the pre-rinse cycle on.Apologies if sounds a tad confusing.
