Smeg DW62wh always draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DW62wh always draining
  • #23694
    chestermike
    Can anyone fill in a couple of blanks please?
    Woke up in the middle of the night (always happens at night!) to the sound of the dishwasher pump.
    the machine appears to be attempting to go through its wash cycle as per normal but with the drain pump on all the time…..
    is the signal for the pump just from the timer unit or does it have a signal to say its ’empty, switch off ‘?
    I have manualy filled the machine, then turned it on (new cycle)pump runs as do the spray bars until the water all drains away. the timer rotates but the pump remains running. (both drain and recircle)
    I overode the door switch and added a pint of water, spray appears but water drained off asap!!
    So can anyone help? if its a new timer it may be me oof to the sales (well timed I suppose..) or may I have a sender buggered/clogged up?
    any thoughts?
    cheers Mike
    #199029
    Re: Smeg DW62wh always draining
    DWF62WH?
    Drain pump will run continuously if the flood protection system is activated. Drain the tray under the machine to reset, then find the leak.
    Power off, of course.
    chestermike
    Re: Smeg DWF62wh always draining
    Thanks for the reply. I did find a very small amount of water under there, strangely enough at the front by the ultra light flood float! I had put it down to a splash due to turning it on its side….
    No sign of a leak, maybe from exuberant filling/sloshing half empty glasses during filling the machine 😳
    thanks again Penguin45.
    Mike 😀
    #199031
    Regosaki
    Hello,
    I have a Smeg Dishwasher Model STA6248-9 that refuses to stop draining?
    I have read the overflow thing but cant seem to gain access to the drip tray beneath the machine. When I remove the kick plate beneath the machine I am confronted with a plastic panel with no visible screws or fastening? Not being overly technically minded this has me baffled. Can anyone help?
    #199032
    some smeg panels have plastic latches that you have to unlock to remove them
    if you still cant do it you can tilt the machine slowly back to allow the water to drian out or
    post a pic so we can see the panel clearly
    Regosaki
    UPDATE!
    So, inspired I had another look this morning.
    I managed to remove the plastic front cover behind the kick plate and inspect the drip tray which is completely dry?
    the pump still runs constantly and the machine beeps 5 times?
    Do I need a new pump?
    #199034
    no the pump is working but don’t know why
    you say its a new timer, have you just fitted the timer or has it been working ok for a while
    Regosaki
    Hi Dave,
    Sorry I meant to say, thank you for your quick responses. Your help is REALLY appreciated!
    So, this is the first time we have had a problem with this dishwasher. We have never used or even know of a timer on it.
    All I can tell you is we switch it on, it beeps 5 times and the far left light on the display flashes (sorry the little icons have worn off over time)
    And the pump continues all the time.
    I’ve tried boiling water and the pump just clears the water and continues to work.
    I’m stumped.hu
    Is there a way of resetting the machine?
    Thank you
    #199036
    sorry mis read things as you came in half way through a post with a different machine
    have a look here
    https://www.manualslib.com/manual/343495/Smeg-Di112-2.html?page=2#manual
    this may be the manual for it but not sure
    look in troubleshoot and see if anything looks like what your getting
