SMEG DWD 612 C Dishwasher – Possible E1 fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG DWD 612 C Dishwasher – Possible E1 fault
  • #50456
    andreawayne
    I have called a plumber out who has checked the pump and filter and checked for kinked pipes and blocked pipes and all is clear. I have reset the programme by turning the machine off and then on again and pressing the button 4 times until the 1st and 5th lights are flashing. I then turn off for 10 seconds and switch on agian and select rinse mode. I press start close the machine and its starts up. After 5 minutes there is a beep but the machine still sounds like its carrying on. I open the door after 20 minutes and there is no water atall, the machine is dry. Please help me solve this without calling SMEG!!!
    #304870
    Re: SMEG DWD 612 C Dishwasher – Possible E1 fault
    The reset procedure is only applicable for the E7 fault, and it doesn’t sound like you are completing that procedure properly.
    E1 is flood protection activated. LED 1 and LED 5 should be lit – what are you actually getting?
    andreawayne
    Hi, I get the 1st light flashing and the 5th light just on!
    #304872
    Have you looked in the tray under the machine to see if it’s full of water?
    andreawayne
    Hiya
    Do you think it could be in need of a replacement timer? Thanks A
    #304874
    This is supposed to be a two way thing – I can’t see your appliance; so the previous question stands. Get the screwdrivers out and have a look!
    If I tell you to buy £100 + VAT’s worth of timer and it doesn’t solve the problem, you’re not going to thank me, are you?
