Smeg DWD1SSE-1 won’t start
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWD1SSE-1 won’t start
Viewing 12 posts - 16 through 27 (of 27 total)
  • #323612
    ServEng
    did the 1st and 5th lamps light up? could take several times seems unrealistic but this is smeg down to a T
    #323613
    JohnBoag
    Re: Smeg DWD1SSE-1 won’t start
    Tried several times – the 1st, 4th and 5th (the first being the eco light) come on every time but never flash.
    Once or twice during this process there’s a clunk from way down below (to the left) so maybe this is the drain pump trying to pump out as there’s still some water in the base of the unit. The filters have been checked.
    #323614
    ServEng
    drain pumps are at the front right 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time disconnect the float switch on the base and see what happens then not sure if you know but you can unclip the base with a flat head if you tilt it back if it still does nothing when you unplug the float switch your drain pump is dead or your pcb is corrupt/blow or is the incorrect pcb is you have just replaced it
    #323615
    JohnBoag
    Disconnected the float switch and tried to reset / start etc but still nothing.
    #323616
    JohnBoag
    I’ve tried phoning Smeg today to confirm that the pcb they’ve sent me is indeed the correct one. All the plugs fit but the actual pcb looks different and has a different code.
    The parts dept is not available until Monday so I’ll have to wait until then to confirm it’s correctness.
    #323617
    ServEng
    if the pcb looks different then it is wrong lol i know this all to well
    #323618
    JohnBoag
    Cheers ServEng! 😀
    I guess then that several smeg pcbs look very similar (where the connections all fit) but are very specific to each model. The code on the old one is 10613130 while the new one is 10613000. I just assumed that over the 5 years since we purchased the dishwasher the pcb had been updated.
    Looks like Monday’s discussion with the Smeg parts dept may get to the bottom of this!
    I’ll update this thread on Monday (hopefully with good news!!)
    #323619
    ServEng
    no probs ill check back monday and see how you got on make sure you give them the correct model number and serial number serial being very important as theyll just send you the wrong pcb if the serial is wrong
    #323620
    JohnBoag
    Just ordered the correct PCB!
    The Smeg parts dept have, apparently, quoted me the incorrect part number originally. I’ve now placed the order for the correct part.
    I’ll post the outcome once the new pcb is installed.
    Thanks again for your help!
    #323621
    ServEng
    typical smeg lol
    #323622
    JohnBoag
    New pcb (correct one judging by the code and the appearance) but same result – the eco light, 4th and 5th light come on but nothing happens – tried resetting but no change.
    Need to decide now whether to call out an engineer or just bin it and buy a non-Smeg appliance.
    #323623
    ServEng
    you need a new alternate valve aswell will take 2 minuites to fit just remember to take the 2 rubber o rings off the old valve and put them on the new one http://shop.ukwhitegoods.co.uk/Dishwash … Valve.html you can find that here
