Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg DWD1SSE-1 won’t start
- This topic has 26 replies, 3 voices, and was last updated 15 years, 9 months ago by
JohnBoag.
June 23, 2010 at 9:02 pm #55415
JohnBoag
ParticipantHi all,
I’ve got a problem with my Smeg DWD1SSE-1 dishwasher in that it won’t start at all. The power light is on as is the eco light but will not respond when I press the start button.
My wife said the door felt a bit stiff the night it went down. I’ve previously replaced the soap dispenser (thanks to advice on here and that fixed the last problem – thanks!). This time I examined the pcb and it was burnt out (black residue over it). The power all round the house tripped so I’m guessing this issue tripped the house’s RCD.
I’ve replaced the pcb but to no avail……any help would be gratefully received!
John
June 25, 2010 at 10:29 am #323598JohnBoag
ParticipantRe: Smeg DWD1SSE-1 won’t start
Does anyone know how to reset the above model? I tried pressing start 4 times with the door open (and closed) several times but to no avail….although I could have sworn a couple of times there was a solitary clunk from the base of the unit.
I’m guessing the door mechanism may be the problem but from reading on here the pcb blowing may have taken the soap dispenser out but I’m hesitant to spend another £60 on parts.
June 25, 2010 at 7:05 pm #323599JohnBoag
Anyone know if the pcb numbers should be the same?
The burnt-out pcb number seems to be 1613130 while the replacement pcb number is10613000?
It’s fits OK and the new pcb lights up the “eco” led but that’s all.
June 25, 2010 at 8:29 pm #323600JohnBoag
Sorry, 10613130 not 1613130
June 25, 2010 at 9:10 pm #323601clivejameson
I’m afraid there’s a distinct possibility that the root of the problem is the dispenser solenoid which has now damaged your new pcb 😕
Maybe time to get an engineer to inspect?
June 25, 2010 at 9:13 pm #323602clivejameson
Sorry…misread your postings! I assume the machine worked ok after replacing the dispenser in which case the door switch may well be the problem.
The only way to check this is to open it up and meter the switch.
Power off at all times :zap:
June 26, 2010 at 10:02 am #323603JohnBoag
Thanks for the advice. Yes, the soap dispenser was replaced about a year ago and the machine has worked fine until last week.
Electrically we’ve linked out the door switch but still will not start.
Not sure if this is helpful but inserting the old pcb results in the 2 far right lights coming on while the new pcb does the same but also lights up the “eco” light.
Looking at the carbonised pcb the connection “A5” was the carbonised section – do you happen to know what this controls?
June 26, 2010 at 10:49 am #323604ServEng
Participantin my experience with smeg replace all pcbs their a nightmare, just to get a bit more information though when you try to start the machine does it beep twice asif it is going to start? or does it start and just constantly pump out?
June 26, 2010 at 10:55 am #323605JohnBoag
No the eco light is solid as are the two far right lights.
June 26, 2010 at 11:01 am #323606ServEng
Participantok and when you close the door does it click in to place properly? and when you start it does it just stay doing nothing or does it start and constantly pump out
June 26, 2010 at 11:08 am #323607JohnBoag
The door closed firmly (the standard clicking noise as per usual). Power on then hit start and nothing happens at all.
June 26, 2010 at 11:10 am #323608ServEng
Participantalso try and reset the dishwasher
Switch the dishwasher on and press the programme button 4 times, within 3 seconds.
1st and 5th lamps should light Note:You may have to do this several times before it works
switch off
count to 10,
switch on
run the rinse programme onlyIT IS ALSO POSSIBLE YOU HAVE THE WRONG PCB IN THE MACHINE IF FOR EXAMPLE YOU HAVE THE JANUARY 2009 MODEL AND SMEG CHANGED THE MODEL IN MID 2009 THEY MAY HAVE CHANGED THE PCB THE MACHINE MAY LOOK THE SAME HAVE THE SAME MODEL NUMBER BUT PARTS ARE DIFFERENT
June 26, 2010 at 11:12 am #323609JohnBoag
Just to answer your earlier question the last time I had a problem (about a year ago) the machine beeped started for less than a second then stopped – I replaced the soap dispenser and all was well.
This time abosolutely zero activity! – the only difference between the carbonised pcb and the new one is the eco light comes on solid with the new one.
June 26, 2010 at 11:15 am #323610ServEng
ok read above
June 26, 2010 at 11:16 am #323611JohnBoag
Tried to reset but no response (no change in lights)
