Smeg DWD61 themostat
  • #7354
    AMS
    Has anyone got the number/price/source of a thermostat for a Smeg D/W model DWD61? The machine wasn’t heating so I reset the (tripped) manual cut out and all was well. Next wash, no heat. I’m assuming the machine is overheating due to a faulty stat. Is this a fair assumption? Anybody got any other ideas before I go back to it?
    Could be the stat, I’ve seen it happen before. Can also be a “hot spot” on the element or something lying on the element across the stat as well.
    Price etc. is no problem and Dave or I will check that in the morning for you.
    AMS
    Re: Smeg DWD61 themostat
    That was b****y quick!
    Cheers Ken
    #122838
    Have had this problem, usually changing heater and stat sorts it. if its not tripping everytime, it could be you placing a bowl in rack over stat, causing a “mushroom” effect trapping heat in a small area thus tripping stat.
    Hope that helps
    G
    #122839
    shane
    AMS wrote:Has anyone got the number/price/source of a thermostat for a Smeg D/W model DWD61? The machine wasn’t heating so I reset the (tripped) manual cut out and all was well. Next wash, no heat. I’m assuming the machine is overheating due to a faulty stat. Is this a fair assumption? Anybody got any other ideas before I go back to it?
    Knowing Smeg d/washers, do not rule out circ. motor overheating and TOC operating. These can be time consuming to locate.
    We usually refer Smeg users to the Corporation Refuse Dept.
    Shane.
    #122840
    There’s three variants Dave, I THINK it’s just colour so anyway, part numbers are…
    818730825 – Tank Stat (not on my price list :?)
    806890373 – Heater (£21.29 list)
    Again, if you’re stuck, the tother Dave should be able to get them.
    Dave_Conway
    kwatt wrote:818730825 – Tank Stat (not on my price list :?)
    That’s because it’s 818730285 😀
    Now superseded by 818731072
    Price for that stat is £11.73 list.
