Smeg DWF 1.1 stops then restarts part way through cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWF 1.1 stops then restarts part way through cycle
  • #82386
    Mark_E
    Hi all
    I have a SMEG DWF 1.1 that will stop part way through it’s wash cycle then restart a few seconds later. It may repeat this 10 times or so before running continuously again for a period.
    I’d be grateful for any pointers as to te likely cause. It’s been thoroughly cleaned.
    #419691
    Re: Smeg DWF 1.1 stops then restarts part way through cycle
    not an unheard of problem
    normally the power supply on the electronic control board
    if you get an engineer from this site he should be able to repair the board
    to give you an idea whats going on. as the machine ages, the power supply degrades, just like batteries running down. machine pump ok, fills ok, and starts washing, then the heater and the soap draw operate drawing more power, and the power supply fails. as soon as the power comes back up again the unit starts again
    hope this helps
