Smeg DWF 66 Dishwasher – Is it me?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWF 66 Dishwasher – Is it me?
  • #33488
    Suds
    OK, I worked out what the Electrical banging was. When the machine was assembled, the soap dispenser had been fitted with the seal poking through into the void in the door. The result was that water would get in there and turn to steam misting up the controls. The rinse-aid low level lamp is illuminated by a reed switch situated under the reservoir. This was getting wet and tracking to earth. The heat generated by the short circuit would evaporate the water causing the short and the machine would then continue until the steam condensed again and caused a short.
    So, I have fixed all that and the machine works, well sort of. It will work for about an hour and then stop the timer light will go out for about a second and then it will ‘click’ like a relay has tripped and run for a second or two and then stop again. It will do this about half a dozen times and then continue to the end of the wash.
    Is this normal I really cant say if it has always done this as I have not been keen on sitting there watching it while it is working – at least with a washing machine there is something to watch – Is this normal or is something else wrong with it?
    Thanks,
    Ralph.
    #238886
    Re: Smeg DWF 66 Dishwasher – Is it me?
    No, it’s not normal. The dispenser solenoid is a known problem causer with the electronics – replacement is the only solution. The mains suppressor is the other regular problem. It breaks down under load and can lead to pops and bangs and the electronics blanking out.
    Power off when investigating.
    Suds
    Thanks Penguin45,
    I have studied this further and it does appear that it happens at the same point in the program, every time. (45 minutes from the end) It sounds like a relay tripping, NOT an electrical short or arcing.
    This makes me think that it is the dispenser solenoid but would this cause the display to go blank?
    Also, where can I get the part number and subsequently a replacement?
    Thanks for your patience and help with this.
    Ralph.
    #238888
    Dispenser unit is p/no 812890061 – spares@ukwhitegoods.co.uk will be able to get you one promptly.
