Re: Smeg DWF1 014870600
Yep that’s the fella….if it’s tripping to the first level when there’s hardly any water at all then it’s out of adjustment provided the matrix is spotless. They used to put a blob of paint on the adjuster screws to hold them but i haven’t seen any with this for ages now, and i have had the odd one or two that re-adjust themselves as a result.
If you’ve got the time and patience you can work out which screw is which (trip level and difference level) then readjust but as this has a timed top-up it might be a lengthy process as the only way is trial and error 😕
Pragmatically speaking, fit a new one 😆
