Smeg DWF1.1 Soap Dispenser
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWF1.1 Soap Dispenser
  • #31487
    rawhead
    I have read several threads here about a problem I have concerning a dodgy soap dispenser. I have found the bit I need to order, but donโ€™t know how to replace it. Can anyone point me to some instructions? Which screws to remove etc.
    My local guy canโ€™t find the problem and has told my the machine has had it. ๐Ÿ˜ฏ But I want to try the dispenser trick (ยฃ35 if it doesnโ€™t work is a bit of a risk thoughโ€ฆ)
    I emailed for one of the repair guys on this site but got no reply (Iโ€™m in North Norfolk) ๐Ÿ™
    Cheers ๐Ÿ™‚
    #231346
    clivejameson
    Re: Smeg DWF1.1 Soap Dispenser
    We are unable to give complete instructions in case you or anyone else reading this post injures themselves…suffice to say that this repair isn’t rocket science, the dispenser is in the door so that’s the bit you need to open up. The dispenser fixings will then be obvious ๐Ÿ˜‰
    Don’t forget to unplug before doing anything :zap: and watch out for razor sharp door edges ๐Ÿ˜‰
    #231347
    rawhead
    clivejameson wrote:We are unable to give complete instructions in case you or anyone else reading this post injures themselves…suffice to say that this repair isn’t rocket science, the dispenser is in the door so that’s the bit you need to open up. The dispenser fixings will then be obvious ๐Ÿ˜‰
    Thanks :tup:
    #231348
    rawhead
    ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
    Yahoo! Just put the new soap dispenser in and it’s fixed! ๐Ÿ˜€
    Thanks to this place, saved ยฃ400 on a new machine. Cheers guys…
    Bought the Dispenser from espares for ยฃ31.49 + with 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} quidco
    http://www.quidco.com/?search=espares
    Well worth joining if you’re not already a member…
    #231349
    clivejameson
    Nice one :tup:
