smeg dwf1 not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum smeg dwf1 not draining
  • #8035
    i am having trouble with smeg dishwasher ref dwf1
    basically not washing and when cycle finishes the water is not draining away.
    i have checked for blockage and cleaned filters this seems ok!
    anyone have any ideas.
    cheers
    phil
    #126551
    Can you hear the drain pump running, Phil? If you can, the blockage may well be at the undersink coupling, if appropriate. If you can only hear a faint humming noise, the blockage is in the pump motor iteself (down below……….).
    Pull the plug before sticking fingers in!
    Re: smeg dwf1 not draining
    thanks for that penguin 45
    how would i access the pump to check this
    is it below the filter at bottom or underneath as in turn machine upside down.
    once again thanks for your help
    phil
    #126553
    Dont turn it upside down ❗ It can be accessed by the two screws holding the panel at the front under the lower edge of the door. Remember to pull the plug out before attempting anything.
    #126554
    thanks for that
    i now have the front panel removed and have revealed the workings etc
    is it a simple job to check the pump for blockages or will i need to call out an engineer in the manchester area if so anyone reccomend a good one.
    cheers
    phil
    #126555
    The pump is right there in the front but a bit fiddly and messy to get out. Whatever, make sure the dishwasher is un plugged before touching anything. Use this link to find an engineer: http://www.ukwhitegoods.co.uk/search/fi … ineer.html
    #126556
    thanks for all the advice
    got machine working again.
    ok for 2 weeks
    but now smell and smoke coming from top of door like burning rubber!
    any suggestions.
    #126557
    I suggest you unplug it and get an engineer in!
    click here to try our repairs@ service
