Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › SMEG DWF409 stops mid cycle
- This topic has 4 replies, 2 voices, and was last updated 18 years, 7 months ago by
truckbusuk.
August 24, 2007 at 11:29 am #30034
truckbusuk
ParticipantHi, nubie here, interesting site you guys have 🙂
I have done all the searches and read most of the SMEG dishwasher posts, but I think I still need a step for a hint, hopefully you can assist.
The machine is approx 4 years old and has never had an issue before.
The problem is
The washer runs through its cycle (all programmes) but just before the drying cycle starts (3rd led lit) the machine stops, and shows leds 2,3 &4 lit. If you open the machine there is very hot water in it.
If you annul the programme, the machine drains, and resets its-self, you can then start any programme and it work through its cycle until just before the drying cycle starts.My assumptions are …
The pumps are OK as the seem to work
The programmer board is OK – this is positive thinking rather than any techincal opinion
There are no blockages, water drains OK
The problem is heat related as the machine is hot and the water is hot when the cycle stops.Cheers 🙂
August 24, 2007 at 9:44 pm #225616Penguin45
ParticipantRe: SMEG DWF409 stops mid cycle
It’s not logical – 2, 3 + 4 lit is E7 – flow meter failure. This device is not fitted to your appliance. E7 is also a general failure, so next time you come to use the machine, it should do it straight away once it starts to fill. You could try the re-set procedure (Put ‘SMEG AND reset’ into “Search” – plenty of references), but I doubt it will correct it.
Beyond that, you’ve got me!
Penguin45.August 24, 2007 at 10:10 pm #225617truckbusuk
Thanks for the prompt reply Penguin45, I’ll dig that out and let you know what the outcome is.
Cheers 🙂
August 28, 2007 at 12:51 pm #225618truckbusuk
Thanks again Penguin45, your a star. Despite you doubts the reset worked a treat.
The machine has now done several loads on each programme and no repeat of the mid-cycle stop.
I was reluctant to report back too early, but thats 4 days and 1 birthday party’s worth of loads and everything seems OK.
I’ll keep my eye on it and report back in a week or so, but just now all appears well.
Thanks again for the advise 😀
October 24, 2007 at 2:08 pm #225619truckbusuk
Well, here is the update, I’ve being putting this off for a while in fear I would trigger a “Murray Walker Moment” and hex’d the machine.
The machine has worked without problem since I followed the reset from Penguin45.
Again thanks very much great advice and a great site. 😀
