Smeg DWF409 – suspected door switch
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWF409 – suspected door switch
  • #72725
    james_stan
    Hi all
    My DWF409 has started playing up. Sometimes it will run all through a program and sometimes it will stop just after the fill stage. Last night I watched it and when it failed all LEDs inc power went out – dead. Opened and shut the door and it started again.
    Again it packed in but this time I banged then pushed against the door handle region. It started again I waited a while and went to bed and in the morning program was completed.
    Does this seem like a dooor switch fault ? If so can you recommend the best place for a replacement ?
    Cheers
    JS
    #385410
    james_stan
    Re: Smeg DWF409 – suspected door switch
    Update –
    OK checked the door switch (Bitron type S16) and all seems Ok.
    Thinking about it also this couldn’t really be causing the power-cut issue as the mains button LED also extinguishes when
    the unit was stopping part through a programme. Banging on the
    front panel though does ‘bring it back alive’ so a loose connection or dry solder joint somewhere I imagine.
    Strange thing is that once it ‘gets going’it’s usually ok until the end of the program..
    .. not sure where to look next – the feed to the switch I guess. 😐
    BR
    James 😐
    #385411
    james_stan
    I think I isolated the fault to the main plastic encased pcb.
    examined it for wobbly joints but nada. Put it back together and now properly nadgered. Not worth a 120 + VAT for new pcb on a ten year machine so ordered a new machine (principally to keep Mrs quiet) – not happy with the outcome but what can one do.. ?
    JS
