SMEG DWF409ss
  • #48280
    stourportsaddler
    I have a strange problem with my Smeg Dishwasher.
    I press the on / off button and all the phase lights are lit ( no error code for this) but the on / off switch led is not lit!! I cannot get any sounds or response from the program buttons.
    I’m guessing it may be a mains supressor fault but maybe someone has seen this problem before and can help.
    Cheers
    #296173
    Re: SMEG DWF409ss
    Almost certainly a corruption issue of some sort – mains suppressor is possible, the dispenser unit is a “big bad wolf” on these things, even the motor start/run capacitor starting to break down can cause issues.
    However – without physically replacing components, it is impossible to work out whether or not the pcb is damaged, or just corrupted by the other components.
    As a professional repairer, I carry a selection of components which allows testing by substitution. This can prove to be an expensive route for the home repairer to take as SMEG components are on the expensive side.
    Sorry to sound a bit negative, but there just isn’t an easy answer to your problem.
