SMEG DWF409WH D/WASHER
  • #11141
    DAR01
    Going to this one on Monday,
    Customer says sets on prog, presses start, pump ops for 2 secs all lights on, then does nothing else.
    Any ideas please.
    Mike
    #144091
    Lawrence
    Re: SMEG DWF409WH D/WASHER
    Check the solenoid on the dispenser for o/c ,Don’t know how but it causes this fault
    Lawrence
    #144092
    DAR01
    Thanks I’ll let you know what Ifind.
    #144093
    clivejameson
    …and if when you meter it you get a normal reading, try bending the contacts up and down slightly which will show the break in the circuit if it’s faulty 😉
    #144094
    DAR01
    Thanks for the info,spot on with the diagnosis.customer amazed that I was able to fix it straight away.
    Especially as he is an X ray machine service engineer.
    It’s easy when you know the answer. 🙂 🙂 🙂
