SMEG DWF614SS
  • #25555
    DJ-ApPlIaNcEs
    Can anyone tell me the part number for these gromits for a SMEG DWF614SS or a substitute. and where to order from, as you see one of these has given up the ghost. Thank’s.
    http://img.photobucket.com/albums/0803/ … IC0333.jpg
    #206364
    clivejameson
    Re: SMEG DWF614SS
    Hi Doug, are you sure you haven’t got a partial blockage somewhere causing a pressure build up?….i’ve never seen one of these fail before and in cases where i’ve had to seperate the parts for other reasons, i reassemble them with a little vaseline and haven’t had a leak yet….
    #206365
    Re: SMEG DWF614SS
    They leak like crazy. just strip, clean and re fit with a little vaseline and they will be fine. Have known others to fit 2 o rings as there is room.
    754131307 O RING FOR AIR BREAK 1
    #206366
    DJ-ApPlIaNcEs
    Re: SMEG DWF614SS
    Thanks guys, yes when i removed the side and did a rinse water poured out, think the owner never used salt to keep the limescale down, it was like this all over the filter too. 😀
