SMEG DWF614SS Diverter Valve
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SMEG DWF614SS Diverter Valve
  • #49928
    legsthediver
    NEVER been into 1 of these before. Fault code is E8 which suggests ‘Diverter’ Valve needs attention.. Can any one tell me where valve is situated and how to access AND service it.. MANY Thanks…
    #302770
    bzz67
    Re: SMEG DWF614SS Diverter Valve
    From memory (which isn’t great), i think it is in a hose at bottom front. it has a flap in there that opens and closes, may just be sticking.
    #302771
    bzz67 wrote:From memory (which isn’t great), i think it is in a hose at bottom front. it has a flap in there that opens and closes, may just be sticking.
    too true about the memory! 😥 ( I know the feeling though!)
    its at the back, centre, just next to the circ pump and fed from a hose from it, circular. 2 hoses and the 3rd water connection is direct into the sump under the lower spray arm. common failure. Have to repalce as its usually a leak from it that starts the problem. only retained by 2 screws and the hoses so an easy fix. (tip machine on side after first emptying the remains in the sump and the regen reservoir) You dont get the 3 o ring seals with the new one so you need to remove these and fit them back on the new one. 819130468
    #302772
    goosegreen
    Did my first one a couple of weeks ago, following P45s advice. Easy job once you get the machine out. Masterpart supply them:SMG819130468 at about: £35 +.
    Goose
