Smeg DWF614ss with no fault code
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWF614ss with no fault code
  • #70519
    jmh69
    Hi all
    I’ve got a Smeg DWF614 that has a couple of faults. 1st is that it works fine on the rinse programme but on all the others it runs through the programme ok until it gets to 2 mins from the end then it goes to 5 minutes and continues until you switch it off. Also when the water doesn’t heat up yet there is continuity across the heater terminals.
    Anyone with any ideas please?
    #378281
    mdaservices
    Re: Smeg DWF614ss with no fault code
    Hi IT COULD BE A DRY JOINT ON THE PC BOARD THIS WOULD ACCOUNT FOR A INTERMITTANT FAULT WITH HEATER.
    REGARDS Malcolm
