Smeg DWF64
  • #60976
    rocker
    Brought a Water seperator part No 819130468 for above.. the orginal has 3 O rings fitted to the neck that fits into the base, (thats why I am changing it, as it leaking) it dosen’t come with these, anyone know part number, and supplier. please.
    #344416
    bobnorris
    Re: Smeg DWF64
    These are probably the normal smeg O rings that i’ve used many times on smeg and diplomat.Part number is SMG754131307, around £3 each from Connect Distribution(Electrue),daylight robbery.
    Cheers Bob.
    #344417
    Re: Smeg DWF64
    bobnorris wrote:These are probably the normal smeg O rings that i’ve used many times on smeg and diplomat.Part number is SMG754131307, around £3 each from Connect Distribution(Electrue),daylight robbery.
    Cheers Bob.
    wrong info I am affraid, these o rings are much thinner section. To tell the truth, the o rings will not be the cause of the leak, it will be the seal within the alternating valve itself that is leaking, I have always re used the old rings and never had a recall, there are 3 of them in parallel after all!
    the part number is 750212244 if you really feel the need to change.
    #344418
    rocker
    Re: Smeg DWF64
    Thanks Eastmark, I realised Bob was incorrect, thanks for your advice, I took it to be the o rings, as you know its impossible to identify exact leak when testing. I will use orginal O rings after your advice.
    Cheers john
