Smeg DWF64SSE 1st and 3rd lights (of 4) lit = not fill.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DWF64SSE 1st and 3rd lights (of 4) lit = not fill.
  • #39010
    Switch on, prog 2, pumps operates approx 30 secs, then machine beeps and displays above error code. Page 65 of the bible says “Fault codes for E5 generation.. **
    E5 .. no fill”
    This is true.
    Have powered up Aquastop on flying lead and it works OK.
    Removed venturi matrix thing on rhs and looked at it.
    Put it back.
    Still not working.
    Checked disp. solenoid 1600ohm.
    NTC 12kohm
    regen solenoid 5kohm
    p/sw 1 click
    Extracted pcb and looked at it.
    Put back pcb, squeezing plugs.
    Still not working.
    No sign of leaking into base.
    No sign of anything.
    Is this one for the blacklist?
    Mike.
    **Am I on the right page?
    #260925
    Re: Smeg DWF64SSE 1st and 3rd lights (of 4) lit = not fill.
    Check the matrix on the r/h side – secondary feed to the float switch off that. If it sludges up (or the tube through the sump) all sorts of weird things cab happen.
    Thanks Chris. I’ll probably be going back in about a week. Awkward dishwashers can wait till I get washing machines sorted.
    Mike.
