Went to this box on Saturday. Full of a cold and not wanting to do much, but info so far is..
The first and last wash lights are lit whatever you select.
When started it will pump out and let water in at same time.
Water in base drained, meggered a little low so have rebooked to retry when dried out.
Is the light sequence a fault codeto let you know the flood switch has activated? No manual with it and she can’t remember what lights normally came on at the start.
TC
