SMEG DWF64SSE won’t drain, then won’t fill
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG DWF64SSE won’t drain, then won’t fill
  • #48472
    HBtroll
    New here
    Above unit, initially failed to drain properly. Otherwise was working fine. Expected it to be blocked filter or something like that.
    Gave it a clean, made sure waste pipe etc were clear. Ran a cycle empty to make sure and flush the system. All was fine, except residual water still inside.
    Put the thing back in it’s hole. Now it won’t fill.
    Fault lights- There are only 4, not 5 like some info suggest.
    (reading left to right lights 1,2,3,4)
    Turn it on- lights 2,3,4 illuminated
    quiet mechanical/ticking noise for 20 seconds, then lights 1,3, illuminated
    We have pulled water through the system, warm water in the sump, drawn into a bucket, very little debris.
    Water supply is healthy.
    What is the error code telling me exactly?
    What can I do about it?
    Urgent help required, before fairy-hands syndrome kicks in.
    #296686
    Re: SMEG DWF64SSE won’t drain, then won’t fill
    As far as I can tell, the lights suggest a failure in the temperature control circuit – most likely the the sensor or “ntc” device.
