hi been to this for overfilling cleared sump & hoses also pump all were blocked Fault code C2 is showing what is this code & how do i clear it thanks Steve.
Have a search for E2 error….loads on here about it. If there was a lot of muck in the machine then odds on it’s got into the matrix on the RHS. You may be able to flush it otherwise replacement is the way to go 😉
