Smeg DWF66SS E3 Error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWF66SS E3 Error
  • #12081
    hesmas
    I recently started getting the E6 error code and the base of the dishwasher was full of water. I have since cleaned it all and checked the pipe is clear, this now seems to be fine and drains the water.
    It has now started with the E3 error, the water does get hot but it makes some strange noises. Could this be the pump?
    Thanks 😀
    #147830
    Dave_Conway
    Re: Smeg DWF66SS E3 Error
    Yes, it could easily be the circulation pump/motor at fault which may also have been leaking in to the base. Either that or the leak has damaged the motor possibly.
    Power off if you go in and have a look please :zap: or call an engineer if you’re unsure, Repairs@ should provide one 🙂
    #147831
    hesmas
    Had a brief look in the bottom but nothing obvious other than maybe the pipe is blocked, but doubt it.
    Guess I will call an engineer, thanks for your response.
    Cheers
