Re: SMEG DWI 410 no water from the spray arms
There are two solutions to this, both of which involve the use of No.1 earhole.
After the machine has filled, can you hear a faint humming noise? If you can, there is power going to the motor and the capacitor may well be the solution; unless the pump is jammed by a foreign body. You’ll need one of THESE.
If you can hear the motor whirring away, the impellor may have sheared from the pump shaft and may not be moving the water. A pump housing and impellor kit may be required.
Stay safe – power off if working on the machine.
