Re: Smeg DWI 46 does not heat
housemaker wrote:Does this mean the heater element does not work – which might be worth to call the service and change – or what else could it be?
Not exactly – it means that no rise in temperature has been detected in the time allowed. Heater is possible culprit, also safety thermostat tripped or PCB failure.
Complex machine, so professional help is your best way to proceed.
Power off if you intend to investigate it yourself.
