Smeg DWI 612 Integrated Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI 612 Integrated Dishwasher
  • #52813
    bobnorris
    I’ve got E8 coming up at start after 30 secs to 5mins.No regular pattern but sometimes it fills AND circulates,then the familiar beep beep and abort.Fitted new board 816290713 and same fault! The handbook says E8 means no water pressure to spray arms but the circ pump works when the prog gets that far.Is there maybe a circ pump pressure switch intermittent?I havent yet pulled it out (loads of work)but its only 2 years old and done no work,clean as a whistle,I dont recon theres any crud around.I also tried the old trick of turning down the tap to slow down the fill which sometimes works.Run out of ideas now. Any clues gratefully received.
    Cheers Bob.
    #313225
    johnsdad
    Re: Smeg DWI 612 Integrated Dishwasher
    E8 indicates o problem with alternate valve, not a pcb problem
    #313226
    bobnorris
    What exactly is an alternate valve,is it a regen valve?
    #313227
    johnsdad
    its the valve that alternates the wash pump outlet between top and bottom spray arms
    #313228
    bobnorris
    Thanks a lot johnsdad.The alternate valve showed signs of leaking.A new one did the trick.
    Bob
