smeg dwi 612c
  • #57611
    eng14
    dw had water in base and flashing relevant lights to show this,cleared base now will not start and of the 5 lights the 2 on the right hand side are blinking,anyone seen this cant find in fault code book,richard, 😕
    #331737
    smeghead
    Re: smeg dwi 612c
    pretty sure the 2 right hand lights flash when the machine has been set to reset, (default).
    Pressing any prog button gets the machine working again.
    Have you found the leak?
    Clive.
    #331738
    Re: smeg dwi 612c
    disconect the circ pump see if that clears it. could be a slight earth leak caused by the water leak.
