Smeg DwI 67.1 ALTERNATE WASHING VALVE?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DwI 67.1 ALTERNATE WASHING VALVE?
  • #26831
    cornwell40
    Hmmmmm 😕
    What problem is this likely to cause?
    Looked at above dishwasher today, anti flood in base tripped.
    Dried it out and tested for leaks then found that it fills, the motor cuts in but no ccirculation at all. Thought it would be a motor impellor fault but found this ALTERNATE WASHING VALVE when I checked the Servevast site.
    If this has packed up could this be the fault or am I secong guessing myself.
    Tony C
    #211545
    Re: Smeg DwI 67.1 ALTERNATE WASHING VALVE?
    Failed alternator would still allow circulation to at least one rotor.
    Often the motor shaft rusts on the thread of the impellor giving the impression the circ pump is working but the impellor is not actually turning. New circ pump required I am affraid.
