Smeg DWI 67.1 Dishwasher Error 7
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI 67.1 Dishwasher Error 7
  • #14713
    Navillus
    Machine goes on cycle for a minute or two then beeps with an error code 7, no water has acutually entered the machine and the tablet is untouched …. any ideas….?
    #160544
    NWAR
    Re: Smeg DWI 67.1 Dishwasher Error 7
    Navillus,
    Your machine is registering a fault with part of the pressure fill system.
    This is most likely a fault with the board to be honest, and it may well just need reset. Do a forum search for Smeg AND reset or Diplomat AND reset to find out more about how to try this.
    There is also the possibility that the board may have failed (£126.80 excluding VAT & P+P to replace).
    There may also be a blockage within the fill system.
    I’d try a reset first, and if that doesn’t cure the problem I’d recommend that you get an expert in to diagnose and repair the fault for you. Try Repairs@ for someone local.
    #160545
    Navillus
    Thanks for the info much appreciated….
    #160546
    NWAR
    Navillus wrote:Anybody know how to reset a smeg Dishwasher DWI 67.1, there are plenty of references about resets but I cannot find any description of how to actually carry the reset out.
    Any help would be much appreciated.
    #160547
    NWAR
    Dave_Conway wrote:If you use the search and use this phrase (without the quotes) “diplomat and reset” you’ll find it then 🙂
    #160548
    NWAR
    NWAR wrote:Open door
    Switch on with door on/off button
    Within 3 secs (before display comes on) press programme button 4 times
    Lights 1 & 5 should now be flashing (if not repeat until you have this situation)
    Press programme button once more and you should be left with only the 5th light flashing.
    Switch off (don’t close door)
    Leave for a few seconds then switch back on.
    Select programme and close door
    Machine should now work (stick it on a rinse – if it gets past the main fill you should be OK)
    #160549
    NWAR
    Navillus,
    I’ve moved your other post in here and deleted that thread to keep things tidy; there’s enough Smeg/Diplomat+reset threads out there already.
    I’ve posted the information you were after in here as well to help you out.
    #160550
    Navillus
    Your the Boys….
    Thank you for all your advise…..
