Smeg DWI 67.1 pump impellor fitting!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI 67.1 pump impellor fitting!
  • #17281
    db2boy
    As in my post here :-
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=13655
    my impellor is broken and was no longer attached to the pump shaft.
    I ordered my part and it arrived today 🙂 I just went out to workshop to fit it to the pump. I thought it would be a case of screwing the threaded pump spindle up into a thread in the impellor housing. The impellor housing isnt threaded though!
    Do I need to tap the impellor housing, just create a thread my screwing the spindle into the housing plastic, something else? Can anyone advise please?
    Many thanks
    Ant
    #173609
    Re: Smeg DWI 67.1 pump impellor fitting!
    Normally the thread is recessed in the moulding. Check very carefully the thread on the shaft – a lot are left handed.
    db2boy
    Penguin45 wrote:Normally the thread is recessed in the moulding. Check very carefully the thread on the shaft – a lot are left handed.
    Thank you for the reply.
    There is honestly no thread in the moulding, it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} smooth. A left hand thread I can handle, but being smooth I wasnt sure what to do next!
    Rgds
    Ant
    #173611
    Dave_Conway
    db2boy wrote:There is honestly no thread in the moulding, it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} smooth.
    I would say almost without doubt that it should be. It is possible that it wasn’t threaded correctly at the factory but very rare.
    Let me know please 🙂
    #173612
    db2boy
    Hangs head 😯
    OK so there was a very fine thread towards the end that I couldnt originally see – put it under the inspection lamp and I could see it!
    Thank you for the support, Ill go back and stand in the corner now 🙂
    Rgds
    Ant
    #173613
    Dave_Conway
    No probs Ant, presumably all is now well ? 🙂
    #173614
    db2boy
    Dave_Conway wrote:No probs Ant, presumably all is now well ? 🙂
    Dave,
    Yes once again machine is working like a dream – again thank you for everything 🙂 I also took the time to fabricate a bracket to position and hold the rear leg winder in place – the result is the rear leg works again now which is just soooooo much easier than jamming wood at the back of the machine 😀
    Many thanks
    Ant
