Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg DWI 67.1 pump problem – advice please?
- This topic has 7 replies, 2 voices, and was last updated 20 years ago by
db2boy.
April 13, 2006 at 12:21 pm #17113
db2boy
ParticipantHi folks,
My integrated Smeg DW has stopped functioning correctly and for the 2nd time has a problem with the main (is this the outlet ?) pump. Basically attached to the end of the motor (via 2 screws) is a white housing containing the impellor blade. This is no longer attached to the main shaft of the motor and is the 2nd time this has happened now 🙁 So the machine tries to empty but doesnt as the motor is spinning with no pumping action.The first time I had an engineer replace this but the bill was **massive** and he replaced the whole motor unit as well. Having dismantled it I can see the shaft in the motor that engages the impellor is threaded and I assume it should be attached via this thread to what is left in the rear of the impellor blade?
Smeg dont seem keen to talk to me because Im not trade (I am very capable with engineering etc 🙂 ) – does anyone know if I can purchase just a new impellor housing to attach to the motor? I would machine a new insert for the rear of the impellor but the unit appears to be factory sealed and not serviceable.
Any advice would be a great help…..
Rgds and thanks
Ant
April 13, 2006 at 12:54 pm #173023Dave_Conway
ParticipantRe: Smeg DWI 67.1 pump problem – advice please?
Amazing, three in one day 😀
Different model but it’s the same part number etc as this one:
http://www.ukwhitegoods.co.uk/modules.p … ic&p=79163
April 13, 2006 at 1:39 pm #173024db2boy
Dave_Conway wrote:Amazing, three in one day 😀
Fantastic – thanks Dave 🙂
I have bonded in a threded insert to hopefully get me through easter but Ill place an order for this now for when it fails 🙂
Once again these forums have been an excellent help.
Rgds and many thanks
Ant
April 13, 2006 at 1:54 pm #173025db2boy
Actually Ive just checked my assembly and the impellor housing appears to be :-
1) In a different orientation to the one shown in the previous link
2) The main central pipe connector on mine is longer
I believe when the engineer first replaced this when broken he had to come back for exactly this reason. Is there another part I should be looking at?
Many thanks for all the help
Ant
April 13, 2006 at 2:15 pm #173026Dave_Conway
The hose is still connected in the other photo making it appear shorter 😉
Also, yours has the newer version fitted (note the two holes where it’s fixed to the motor), Smeg have superseded the part number which is the one you have in your picture so the part number is correct 😀
April 13, 2006 at 3:03 pm #173027db2boy
Dave_Conway wrote:The hose is still connected in the other photo making it appear shorter 😉
Ah ok sorry, I dont mean the piece with the hose attached I mean the central piece.
Just so Im clear, I have the newer item with the longer central connector as shown in my picture? If I order the part number given I will receive this new piece and it will be the housing as shown in my link?
Many thanks 🙂
Ant
April 13, 2006 at 3:21 pm #173028Dave_Conway
db2boy wrote:If I order the part number given I will receive this new piece and it will be the housing as shown in my link?
Yes 😀
April 13, 2006 at 4:22 pm #173029db2boy
Dave_Conway wrote:
db2boy wrote:
If I order the part number given I will receive this new piece and it will be the housing as shown in my link?Yes 😀
Smashing 🙂 Thank you very much for or your help 🙂
Rgds
Ant
