smeg DWI 710
  • #31937
    redchan
    Need some help again with this uesless dishwasher.
    Had loads of bother with it.
    Now does not seem to be heating the water to correct temperature and when ends cycle dishes are still wet.
    Sometimes also keeps washing and does not stop until you open door has been known to run all night (not good)
    No error messages coming up, when it completes cycle it flashes as if completed properley but isnt corrrect.
    Please can anyone give me some help before I condemn to scrap heap!!
    #233005
    Re: smeg DWI 710
    Your previous posts suggest that this machine has PCB control, but the DWI710 has an electro-mechanical timer. Please re-check the model number.
    Assuming that it is a PCB machine, if it were not heating at all you would get a fault code showing. Therefore, the fault lies either with the PCB, or with the water level control. The single commonest SMEG dishwasher problem is underfilling, which will give poor heat and therefore poor wash results. Have a read of this:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=102
    It may help.
    redchan
    Re: smeg DWI 710
    Model number is DWI 710E
