Smeg DWI 710 E1
  • #39310
    Harp
    Hi Ive been searching for the Smeg error code post but can’t find it listed … sorry
    If someone could post the link that be great or maybe know the answer to the error Im getting ?
    Smeg DWI710E1 Type 12043
    from left hand side …. second LED flashes and fifth LED (last) stays perm lit.
    Thanks in advance
    #261996
    Harp
    Re: Smeg DWI 710 E1
    its ok found this .. http://www.ukwhitegoods.co.uk/modules.p … t=dwi710e1
    … is it possible there is just a blockage ?
    #261997
    Harp
    Re: Smeg DWI 710 E1
    Cleaned out waste pipe etc …. still same fault …. starts up fills with water starts rinse cycle …. flushes waste water then stops. Anything I can do or part that is required ? Any help I would be very grateful.
    #261998
    Harp
    Re: Smeg DWI 710 E1
    Ok after trying it only on rinse cycle I now have ONLY the last 2 LEDs flashing (thats both extreme righthand side looking down onto control panel) … what does this mean ? Cheers
    #261999
    jpv_7
    Re: Smeg DWI 710 E1
    Hi there
    I appear to have a very simiar fault – did you get any advice on how to fix?
    I think the error lights were #1 flashing and #5 constant (not sure) and have never been able to get this sequence to happen again.
    Fault is that the machine appears to freeze within 2 mins of starting a new cycle. I can hear water pumping in but it never progresses to a wash cycle, appearing instead to freeze with nothing happening. When I open the door I the water heating element is red hot with little or no water in the bottom of the machine.
    I’ve followed Penguins advice on resetting the machine however it keeps freezing on all cycles. I have used manufacturers guide of press and holding the programme selector for 5 seconds to move it to the end of the cycle before trying again. I then get lights 4 & 5 Flashing. Please help!
    #262000
    Re: Smeg DWI 710 E1
    1st flashing, 5th lit is flood protection activated, however, you say that this was a one-off. It sounds more like you have a problem with the circulation pump – fill should be followed by recirculation. Can you hear a faint humming noise after the fill sequence? The pump is a capacitor start and run device – over time, the capacitor loses its ability to charge and whilst the motor will get power (the hum), it doesn’t get the required delay from the capacitor to start it. Alternatively, the pump could be jammed and unable to turn.
    Test on the soak cycle, btw – no heat. Power off if going in to investigate.
    jpv_7
    Re: Smeg DWI 710 E1
    Hi Penguin45 – thanks
    Just stated clean cycle again to report back as acurately as possible.
    Water goes in and 10 seconds later the humm starts, then there is alteration between water in, and the humm. After about 3 mins, all goes quiet except for the what I guess sounds like faint power vibration of possbly the element heating up.
    #262002
    Re: Smeg DWI 710 E1
    Sounds like a stuck motor to me…….. Capacitor is HERE and is cheap enough.
    I would advise dragging it out and having a look underneath before actually ordering.
