smeg DWI 710 e1
  • #47531
    beno
    I have the above dishwasher flashing the following fault code.
    5 leds on the top edge of the door.
    middle three lit up, far right is flashing.
    can anyone help??
    #293743
    martinm
    Re: smeg DWI 710 e1
    cant seem to find a fault code for that sequence of lights try the reset procedure failing that i,d get an engineer because there are a few things on these that can cause unusual light sequences
    Reset Procedure
    Switch on and press the programme button 4 times, within 3 seconds. The 1st and 5th lamps should light…….. You may have to do this several times before it works! Assuming that it does, switch off, count to 10, switch on and run the rinse programme only.
    #293744
    beno
    Re: smeg DWI 710 e1
    The reset sequence worked after the third attemp. Many thanks Martin.
