Smeg DWI 710E – First LED flashing
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI 710E – First LED flashing
  • #18174
    apesaga
    I have a Smeg DWI 710E dishwasher. When I turn the power on, the first LED flashes and after about 5 seconds the machine beeps a couple of times.
    It won’t actually do anything – the program select button has no effect. Shutting the door does nothing (i.e. the first program cycle doesn’t start).
    This isn’t listed as an error code in the manual, so it’s hard to know what’s wrong. I did lift up the silver panel at the bottom of the dishwasher (inside) and noticed there was some water in there – is it having a problem draining, perhaps?
    Thanks for any help in advance.
    #178017
    Re: Smeg DWI 710E – First LED flashing
    Not exactly not draining, the flood protection system has been activated. The undertray of the machine needs to be drained and the leak located.
    Click the link below for a UKW engineer if you’re not sure how to proceed safely, otherwise power off!
