smeg dwi 710e1
  • #25331
    diy
    Help,
    Sent pcb for repair/check and repairer found that led 2 was stuck on, cant see any lights on when card reinstalled yet continue to have fault,unless its one of the leds you cant see ?
    Anybody know the cure for led 2 and or what the two leds you cant see are for,think a new dishwasher only cure ?
    cheers, diy
    #205455
    clivejameson
    Re: smeg dwi 710e1
    What actually is the problem with the dishwasher? i.e. what does is do or not do?
    #205456
    diy
    Re: smeg dwi 710e1
    the programme times are too long does not seem to be switching the heater on for long enough,after about 5 mins into programme makes click sound 2 bleeps and continues then repeats this every2 mins approx,no visible fault led indications. pcb repairer said I may need to send card back for reset as I should have cured fault before refitting.
    Repairer said engineer would know fault for led 2 stuck on? Heater only on for couple of seconds every 2 mins.
    Cheers,
    diy
    #205457
    Re: smeg dwi 710e1
    If LED2 is flashing and LED5 is steady, you have the E2 error and should read this:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=102
    If LED2 is just lit, I would suspect some sort of computer problem and you should ask your repairer to try again.
    You could try the reset procedure; it might make a difference. Type “SMEG AND reset” into Search for this forum only to find – plenty of references.
    diy
    Re: smeg dwi 710e1
    Tried reset and works ok on rinse programme but otherwise fault as before no visible led fault leds on .Does anybody know what the resistance readings should be for given temperatures for the door temperature sensor? Thanks
