Smeg DWI 710I Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI 710I Dishwasher
  • #27047
    redchan
    All lights come on when powered up, There is nothing happening when I close the door to start the machine.
    Tried several engineers noone wants to check it out say too expensive get a new one.
    Trouble shooting guide does not show this sequence of lights as a fault.
    Can anyone help tell me what the problem may be????
    #212413
    Are all the lights on constant or flashing?
    Flashing would indicate that it thinks that it’s at the end of it’s test mode. Solid would, quite likely, indicate a fault on the timer itself.
    redchan
    Re: Smeg DWI 710I Dishwasher
    All the lights are flashing continuously, do you know what if anything I can do with it ?
    #212415
    Hi Redchan,
    I don’t have the technical at home (I do go home ;)) but if you have search of the dishwasher forum for “Smeg reset” you should find it okay, if someone else can’t recall it or has it to hand.
