Smeg DWI16 12C Lights 4 & 5 on Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg DWI16 12C Lights 4 & 5 on This topic has 3 replies, 2 voices, and was last updated 16 years, 4 months ago by TVRJOHN. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts November 26, 2009 at 12:41 pm #50479 TVRJOHNParticipant Hi folks first posting so be gentle ! :rolls: Having problems with the dishwasher, panel lights 4 & 5 stay on and beeps when switched on. Tried to reset the usual way with no success Does this mean its a PCB fault issue ? Read up on QER Workington for repair, would just like to know if this is the right direction for a solution. PS is the PCB in the door or in the back ? Thanks, November 26, 2009 at 8:16 pm #304933 Penguin45Participant Re: Smeg DWI16 12C Lights 4 & 5 on Lights 4+5 indicate that the programme has completed. If the door latch is in the closed position, you cannot reprogramme the machine. Re-set procedure is only appropriate for the E7 error. Pcb is in the facia – next to the door latch. 😀 Stay safe, power off if you intend to resolve this yourself. Penguin45. November 26, 2009 at 10:05 pm #304934 TVRJOHNParticipant Re: Smeg DWI16 12C Lights 4 & 5 on OK thanks for the reply, whenever it has finished a wash cycle before it has never displayed lights 4+5. So could it be a stuck closed door switch, leaving it in a mode that cannot be reset ? PS when the door is closed a pump momentarily starts then stops and this keeps repeating, does this help with any diagnosis ? Thanks November 27, 2009 at 12:42 am #304935 Penguin45Participant Re: Smeg DWI16 12C Lights 4 & 5 on Ah – the pulsing drain pump – this is not good. You’re almost certainly looking at a corruption issue with the PCB. You’d better have a read of THIS ARTICLE. No simple or cheap solution, I’m afraid. Penguin45. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
