My dishwasher is 5 years old now and was setting off the anti flood switch, I have stripped it all down and on the right hand side at the bottom there are two clear pipes that run into a chamber with clean water in it. The pipes both have black o rings on them and one of them is leaking. Can this be repaired easily or what would the rough cost of this be?
Thanks for the advice, i ended up striping it all down and putting a bit of PTFE
tape around the washer to seal it abit tighter. This appears to have worked but I have ordered a new seal from Smeg which is due in about a week.
