smeg dwi409c
  • #45117
    robbo1973
    been here today for fault of first light flashing (flood protection) emptied base and ran now it starts pumping out then fills at same time then eventually it fills properley but when it gets close to level it beeps 1,2and3 lights flash 4 is out and 5 is solid,I cant find a fault code for this in my book any ideas?
    cheers chris
    #283688
    Re: smeg dwi409c
    sounds like its a E7 error (flow meter). Although it doesnt normally effect the 45cm models, it may only be a software glitch. try the following:
    With the door open, turn on the appliance and within three seconds push 4 times on the program selection
    button – The test program has been selected if the SOAK and STRONG LED’s are flashing
    This LED combination represents the test program for the appliances that have a flow meter.
    If the above indication is not shown on the appliance, switch the appliance off and try the sequence again until the above LED’s are shown on display.
    Now push on the program button once more to select the version ‘without flow meter’, check that the SOAK
    LED goes out,
    Do not close the appliance door, to complete settings switch the appliance off.
    Now switch the appliance ‘on’ and test on a SOAK program.
    As it says in bold, sometimes it takes a few attempts to get it into the correct mode.
    this will not account for the water in the base though!
