Smeg DWI45.1 Fault without Errors
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI45.1 Fault without Errors
  • #79617
    jonsutters
    I have a slimline model 12140 which seems to work fine on the ‘cold prewash’ program, but with all other programs requiring heating, the water does not heat.
    Also, once it begins washing (in said cold water) it gets endless stuck in a perpetual 70second loop of pausing, bleeping (the same short bleeps as after a door has been opened & closed mid program), and continuing – thus never finishing a program.
    No error lights appear at all.
    Any ideas?
    Thanks in advance, Jon.
    #409986
    Re: Smeg DWI45.1 Fault without Errors
    board power supply
    common fault
    if you call smeg they will change the board
    call a good local engineer they may be able to repair the board
