SMEG DWI45 Air Break Leak
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG DWI45 Air Break Leak
Viewing 1 post (of 1 total)
  • #63501
    eddmcm
    I noticed water leaking from under my smeg DWI45, I removed it and searched for the source. I found water all the way up the right hand side of the smeg, so I removed the side to expose the air break. Exercising caution I ran the smeg with the cover off and found large amounts of water spraying out of the side of the air break! The water leaks from large holes that seem to be for air ventilation. If you face the air break on the dishwasher then the water leaks from the top right corner of the air break.
    Questions: Why is this happening, Is the air breaker broken/missing a piece, Is the problem caused by another part???
    Please Advise! 😕
